Водометный катер Била Рассела
Сообщение bottomdweller » 04 дек 2011, 20:37
sorry for not listing my name.
i am bill russell and i build these jet boats in montana USA
www.jetboatsofmontana.com
bottomdweller
Сообщение bottomdweller » 04 дек 2011, 20:41
also sorry that i do not speak russian
but i can see some of you speak english
bottomdweller
Сообщение Ajak » 04 дек 2011, 21:14
Bill Hi, I'm glad to see you here!
You changed the nick name? You're at all forums with the nick JBM !
Use the Google translator to communicate in Russian http://translate.google.ru/#en|ru|
Ajak
Сообщение bottomdweller » 04 дек 2011, 21:34
yes i use [ jbm ] in the USA but did not think any body in russia would know me.
i must be wrong with that
using a translator is cheating for me i need to learn russian this would be better
bottomdweller
Сообщение Ajak » 04 дек 2011, 22:45
Tell me Bill, what you've achieved a maximum speed of the water jets, Scott 751, what engine showed the best result, with some impeller and the ring on the nozzle, at a boat?
Ajak
Сообщение bottomdweller » 04 дек 2011, 23:09
the boat with the ecotec 175 hp and the scott 751 jet pump went 40.1 miles per hour or about 65 kph at 4000 feet elevation
bottomdweller
Jet boat from Bill Russell
Сообщение Ajak » 05 дек 2011, 06:30
Bill is clear. It seemed to me that the rate for such an engine and water jet is small, if properly selected impeller?
Pitch Impeller 19 "?
What fuel consumption, and which at a rate of PRM Ecotech 40.5 miles
How much weight boats?
Regards
Ajak
Сообщение дядя Вася » 05 дек 2011, 19:51
во...... делаааа....... :D
"барин" за"америкосов" взялся..... бедолаги.
Ну а по делу - 40 миль в час(64 км час) при моторе 2.4 литра 170лс.....ну не шибко круто, учитывая фирмовый матор, и "скотт" - водомёт.
Может я чего не правильно делаю ? - но моя гаражная самоделка с мотором 2 литра , при длине 5.5м 4 чел - бежит 65 км час......Правда водомёт - чухонский.
А вообще такую лодку Сильвер Кожинов может сварить...за два дня... это как "два пальца об асфальт".. видел я его станочный парк.
Да еще имея...... аналогичные моторы и водомёты Живьём на складе...
А везти такую лодку из Америки - 40% таможня, 6000$ - доставка, "бескорыстность" продавца - 20-50%...иотого
ДВА КОНЦА.
Сообщение bottomdweller » 06 дек 2011, 03:50
yes 40 miles per hour at 4000 ft elevation so on the river should see WOT speed of 44 miles per hour
we set the water cannon and engine up to give better low end grunt out of the hole to get on stem fast with big load like moose and deer
max rpm is 5400 rpm at 40.5 mph
all the boats we build we build for hunting so they can carry a big load at slower speeds and get better fuel burn rates
we need this more then fast top speed so we can go great distance on less fuel
is this translating good ? im not sure if it translates them same as i write. when i translate what you guys write in russian it translate only some of what you write
im not sure all you russian words translate with the same meanings . so im sorry if some of what i write does not come out clear
this boat has top speed of 40.5 mph and can carry alot of extra fuel and big load of game like moose and deer
this other boat with a weber 143hp turbo will run a top speed of 42 miles per hour with a scott 751 but it will not carry the same big load as the ecotec will
bottomdweller
Сообщение bottomdweller » 06 дек 2011, 03:57
this weber here will run 44 miles per hour on the river
bottomdweller
