1st test run with kodiak 2.4L vortec 2 stage jet
Сообщение bottomdweller » 06 янв 2013, 20:14
very short test run put shows we can get even more out of this set up
2.4L gm vortec from kodiak and a 2 stage 7 1/2" marine power jet pump
bottomdweller
Re: 1st test run with kodiak 2.4L vortec 2 stage jet
Сообщение bottomdweller » 06 янв 2013, 20:15
bottomdweller
Сообщение дядя Вася » 07 янв 2013, 11:39
Нi Bill
what about size,weight,speed, its ?
Сообщение bottomdweller » 09 янв 2013, 01:10
boat is 16'6" around 1350 lbs.
60" wide bottom
kodiak 2.4L vortec 130hp 4 cylinder gm engine gas
marine power 7 1/2" 2 stage jet unit
we should be seeing around 40 miles per hour after all the testing
we have another set of impellers to test with this week and will post those test results after that
bottomdweller
Сообщение дядя Вася » 09 янв 2013, 10:07
Hi Bill
thank you for answer.
Please inform about weigh Engine unit.
I read one site - 120kg another site - 260kg
Сообщение bottomdweller » 11 янв 2013, 03:34
this should help
right from kodiak spec sheet 186 kg [ 410 lbs. ]
thats complete ready to install and run
bottomdweller
Сообщение дядя Вася » 11 янв 2013, 21:31
"we should be seeing around 40 miles per hour"
mile - 1600 m or 1852 m ?
Сообщение bottomdweller » 12 янв 2013, 02:28
40 miles per hour top speed in this 16'6" blue boat with this 2.4 vortec and 2 stage marine power jet pump
bottomdweller
Сообщение дядя Вася » 16 янв 2013, 11:58
64 km per hour?
Сообщение bottomdweller » 17 янв 2013, 05:27
yes
bottomdweller
